Anyone using Arctic Liquid Freezer II AIO with Maximus Extreme z790?
mrvortep
NOT SOLVED
Hi there. I am planning to use this AIO on my Maximus Extreme z790.*
However, the Arctic website says that it is not compatible with this generation of Extreme motherboard. I’m not sure if that means it’s only compatible with their pump cover replacement, or if it’s just never compatible regardless if an adapter kit/cover replacement.*
Has anyone got any experience using this AIO cooler on the z790 Maximus Extreme?
Thanks!*
EDIT: Arctic came back to me a second time and, sadly, confirmed that the LF II does NOT work with the Asus ROG Maximus Extreme z790 even with the pcb cover removed. RIP!
0 REPLIES 0
