Another Ryujin II 360 AIO Installation question...
debrent64
Since the pump head connections all go the provided ASUS controller and the controller plugs into USB2.0 on the MB, nothing will be plugged into the CPU Fan header.  I'm using the ASUS z790 Hero Motherboard.  Will it auto-magically detect the pump on the USB2.0 header or will I need to disable CPU Fan header monitoring in the BIOS?  Note that ALL 10 of my fans will be plugged into either the ASUS control hub that came with the AIO or a Corsair Commander Core XT I purchased separately.
0 REPLIES 0
