AMD 8150 Build
wjason777
I would like to build a new gaming/ hd movie/ all around system. Been wanting to do this for almost a month now but couldn't get the help and the advice I needed to get started on it. First off I would like to say that I am a newbie when it comes to water cooling and over clocking. I never done of before but always wanted to learn. I now have a i7 965 that I build almost 2 to 3 years ago. If possible I would like to use my psu and case. But sell the other parts.
Here's what I have in mind so far
ASUS Crosshair V Formula AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Gaming Motherboard with 3-Way SLI/CrossFireX Support and UEFI BIOS
AMD 8150 CPU
GeForce 560
2x 600gb WD Raptors
Windows 7pro 64bit
1 tb external Hdd
Thermaltake CLW0211 Bigwater 760 Plus Dual Bay Drives Water Cooling
For the ram I have not made my mind up of what to get it. It so many choices to choose from any ideas?
Far as the hdd goes I would love to try out a ssd but don't know what size to get and what to use it for. Is the raptors that fastest drives hdd other than the ssd? What will be the best 1tb external hdd?
13 REPLIES 13
Mine will be:
Asus Crosshair V Formula Socket AM3+
AMD FX 8150 3.6Ghz AM3+ 8-core
Enermax Maxrevo 1500W 80 Plus Gold
Corsair 4x4GB DDR3 2133MHz DOMINATOR GT I can't find the 2400Mhz freq in my country yet.
SSD OCZ Agility 3 90GB SATA3 MLC 2.5 inch for sistem run
SSD OCZ Agility 3 120GB SATA3 MLC 2.5 inch for games
and 7990 on march 😄
Will be hard with the money but i will do it.
Stres wrote:
Mine will be:
and 7990 on march 😄
How much money are you looking at so far?
all these things are around 2300 eur :eek:
MarkedOne wrote:
You better stay away from Thermaltake; they are cheap and not efficient. If you want a kit you can purchase an entry level Swiftech one ( see the link at bottom ) but it's far better to build your own kit , basically you will need a Water block for the CPU, a reservoir, a radiator with fans , a pump, tubes , some fitting and coolant . But first thing you have to decide what you will cool and what case you gone use, question to know what Radiator will fit there and what size, the efficiency of the system depend on it.
http://www.frozencpu.com/cat/l3/g30/c321/s818/list/p1/Liquid_Cooling-Water_Cooling_Kits_-_Brands-Swi...
What do you think about the Swiftech H20-220 "Ultima XT Plus kit?
