AM4 headers (fans, RGB, etc)
Heini
Level 11
I am considering an all AMD AM4 build but can't find MB's with enough fan headers. I need at least four headers to power six fans. Can RGB headers or pump headerss be used for fans?
Craigo1986
I dont believe you can use the pump headers and deffo not the rgb headers. Why dont you just order some 2 into 1 fan cables seen them on amazon for a few £ and i own a couple myself. i think they even do a 3 into 1.
