air cooling solutions
dnoam
after a dissapointing run with the corsaair hydro 100 as i had to replace 2 units i decided to go for an air cooling solution but i run into space issue , i am using the 1st pci-e slot as i am installing 3 cards and i am using 16 gb of memory so the b2 and d2 are used.as a result i am remaining with a bit small place to place on of those huge 3 fans cooler , any idea for a good solution will be welcomed.thanks
53 REPLIES 53
HiVizMan
Level 40
All will work we just need to take small steps yes.
Do you have all your drivers installed?
Is the OS a new install or one you have taken from another system?
dnoam
new os , and cannot install yet nothing as i cannot boot properly to my os on the ssd
this is what i see , i cannot transfer the corssair to the booting option.
6058
6057
6059
HiVizMan
Level 40
Ah I see.
Power down and clear your CMOS.
Then in BIOS F5
Enter
Navigate to the BOOT menu.
First boot device
Select your SSD
Page up to make it the first device.
Do not disable other others just leave them.
F10 Enter
And you should no boot to OS
dnoam
i am good and running and all is thanks to you............:)
but you will not get rid of me yet as i will go deeper in your high-end Mob.
all of that after i will set up my system
anyhow thanks a lot and if you want to ask be about somthing ells besids computer i will be more than happy to assist
Bwaahhaaaahaaa
You are welcome my friend any time. We are always here.
dnoam
Hi, now all up an running but i had a small issue with fans , i have 1 fan connected to CAH_FAN3 and i tried to connect another one to OPT_FAN2 next to it and thge machine did not fired up ? is it not allown or simply bad connection?
now to the big thing . I am not a gamer or one that runs after the high number for an hooby, i simply want to creat a profile of overclocking that in it all the parameters will be defined in advance and i have to take 1 action to activate it or deactivate it , i do not want to be busy with tweaking while activating it , like pushing a switch to activate supecharge in a quick car.
i aslo would like to know if the big ocercolcking dungle that comes with the MOB has any issues with DVI type?
thanks
HiVizMan
Level 40
Fans - Is allowed and just coincidence that stuff did not work not something to worry about.
Hmm the one action question. You can set up a profile or a save in AIsuite II and when you want to use that just select and let it happen.
Yeah the big dongle has issues with 120Mhz screens. And there is no need for you to even use it if I am honest with you. Have a play with it if you like but the overlay on your screen will drive you nuts if you are gaming.
dnoam
now , the inevitable question (mabybe not in that forum....) what you actually doing better or can you see big leap forward while you system is overcloced?. this is my 4th top of the line asus bord and i never overclocked , it simply the best around without overclocking.
HiVizMan
Level 40
Look everyone has their own reason for buying the board. For some it is the sheer joy of having 1001 different tweaking options, others it is the bling aspect. Me, I use the product because right now it is the best motherboard for clocking the LGA 2011 CPU's and provides me as a bencher with the best platform. If there was a better motherboard I would use it. I am not sponsored by ASUS so I can use what ever I like.
As a bencher you overclock, and there you certainly see the difference between a standard or stock system and a hectic over clocked system. In the real world, the gains are not so clear cut, folders will see a difference, gamers will see some difference dependant on the game they play. Media design types will have improved render times. BUT we are talking reletive to stock here. Mind shatteringly quicker, no. Most of the time the normal stuff we do with a PC is not worth the effort. My 24/7 system for example is always stock.
With a ROG board the choice is yours, and because it is the best that can be made you have the confidence to know if you do decide to overclock it can and will do the job. Always assuming the other bits are up to the task of course. And that is a big thing, a PC is not just the motherboard, or just the CPU, no it is all the bits that make up the complete system and how they work together. ROG boards allow the users to better manage those differences better if they so desire.
dnoam
Thanks and look at MSi Big Bang xpower 2 as it seems more user friendly.
