air cooling solutions
dnoam
after a dissapointing run with the corsaair hydro 100 as i had to replace 2 units i decided to go for an air cooling solution but i run into space issue , i am using the 1st pci-e slot as i am installing 3 cards and i am using 16 gb of memory so the b2 and d2 are used.as a result i am remaining with a bit small place to place on of those huge 3 fans cooler , any idea for a good solution will be welcomed.thanks
53 REPLIES 53
it is dead.........................
HiVizMan
Level 40
Yeah your install looks good to me from images but that does not take away the possibility that one or the fan headers is not working on the board. Could you test that for me.
1.to which fan header i should conect now the cpu cooler
2.if this is the case how do i solve it?
3.made a small test , connected the blue ray writer to the power supply , now the whole machine is not starting up, click and dead, took it out the machine is fireing but the cooler is dead.
thanks.
1.connected the fan to the other fan ports at the top part of the motheboard , nothing came out.
i thin k that might be a faulty outputs in the Bequiet Pro 1200 although it is very strange as i uninstalled it from perfectly working computer
2.can it be any other reason that the machine is not firing up when i conect the blue ray writer to the power supply ? does it matter thatit is 1st boot on that board?
thanks
:o:o:o:o pls do not leave me , found the problem , fan is firing pupm seems to work BUT , bord is full of changing numbers till it stands on A0 than it stopps after a min, nothing on the screen , monitor is not activated.
thanks
HiVizMan
Level 40
hehe
Not a problem. I am not going anywhere for now.
Lets take this in small steps.
  • Power your system completely down.
  • Press the clear CMOS button at the back of the board, In/Out panel.
  • Power up.
  • Del to enter BIOS, or follow the prompt if your system has failed an overclock.
  • Once in BIOS F5 and enter.
  • F10 and enter.
  • You are now in default settings.
  • Does your system boot into OS
And there we stop for now. :cool:
HiVizMan wrote:
hehe
  • Power up.
  • F10 and enter.
i installed just 2 grafic cards n no ssd or another hard drive yet , no blue ray , nothing , just wnat to take it step by step , want to get " DISK BOOT FAILUER ......... " and than continue.anyhow thanks and i will keep you updated.....:o
tell me pls if i am overdoing it................. i will understand (my wife is saying the same)
i follow your instructions but i cannot keep the system up , it is quickly shut down
thanks
HiVizMan
Level 40
OK so your system it will not post to BIOS?
it will, reached till F 10 and than after few seconds shut down.
