Advise on chassis
GOR52
Hi guys,
I want to use the Corsair H110 (280mm) in push pull configuration, but apparently it is impossible to do it on a Corsair C70.
Please suggest chassis where this configuration can be done easly without much complicated modding.
Thanks
4 REPLIES 4
kkn
Level 14
price range and what sort of size tower you are after?
Myk_SilentShado
Level 15
The 110 is a 280mm mate, not 240...the h100 is the 240mm one
TechRaven
The Corsair H110 page lists several models it is compatible with, you may want to check those. I went with the 550D and a H90 because I wanted the quieter case. Good Luck.. And like Myk said the 110 is 280mm, the h100 is 240mm. But the H110 is much quieter according to reviews i've seen.
http://www.corsair.com/us/hydro-series-h110-280mm-extreme-performance-liquid-cpu-cooler.html
GOR52
Myk SilentShadow, ok, it was a slip on my first post. I meant and mean H110. Enough stone throwing...;)
kkn, it doesn't real matter. I need a case where I can do push pull with the H110 without much modifications to the chassis.
But the chassis does not have to be heavy bling!!
TechRaven, you use a H90. The H110 fits in the 550D. I just need to know is there any compatibility issues with other hardware (no interference with mobo, etc). But hey, I wasn't aware of the 550D. That is a sweet chassis. Thank you for making me aware of that. I'm discarding the C70.
Does anybody know if there is enough space for a push pull configuration of the H110 in the 550D?
