advise for pc cooler & ram
vavaishnav
My pc configuration is:
MOTHERBOARD: CROSSHAIR FORMULA-Z
PROCESSOR: AMD FX-8350
GRAPHICS CARD: MSI R9-270X 4GB
RAM: CORSAIR 4GB DDR3-1866
PSU: COLLER MASTER 600W THUNDER
CABINATE: CORSAIR 400R
My question is : AT THIS CONFIGURATION MY PC IS VERY SLOW & I GOT ERROR THAT YOUR PC TEMP. IS 65 DEG AND PC FAN MAKE NOISE.
SO I THOUGHT PC COOLER IS REQUIRED & RAM UPDATE IS REQUIRED
I AM GOING TO BUY CORSAIR H100i COOLER & 16GB G-skill Trident X F3-2400C10D-16GTX RAM
PLESE ADVISE ME WHAT I HAVE TO DO? ANY SUGGESION?
12 REPLIES 12
ShrimpBrime
H100i will do the trick.
Memory faster will not make a big impact on performance.
You did not mention what HDD you are using, but a better upgrade would be to use a SSD for quick system response.
vavaishnav
I thought for ssd but which size is enough 128 gb or 240 gb?
kkn
Level 14
OS only? 120GB ( no programs or enny things like that other then windows ONLY ( operating system ) )
OS and a couple of games? 250gig.
OS and games and programs and so on? 450+gig.
or 1 ssd for OS and 1 ssd for games ( quicker load time in game whit SSD ).
up to you, this is what i can recommend
all in all its up to you and what you can afford.
andlaw
To fix the temperature problem, the H100i is a great cooler.. idle temp will more than likely be around the same, but your full load temps is where you will notice a difference, or should.. Your memory speed @ 1866 is a good match for that CPU, but 4GB is not a great ammount for a 64-bit system and playing games or really anything but surfing the web since OS takes up around 1-2gb..
HDD and SSD difference you can notice.. but only to a certain extent. SSD's now days are such an affordable price, I wouldn't go with anything under 240 since that only makes sense imo.
Korth
Level 14
Your error message suggests that your CPU is overheating and so your slow performance is mainly the result of thermal throttling.
Your motherboard will support up to DDR3-2400, but the DDR3-1866 is the fastest your processor will natively support. A memory upgrade will only increase performance if you also upgrade your processor - and even then not by very much for typical day-to-day usage.
Even the smallest and cheapest SSDs available today are much faster than HDDs and more than enough to run your operating system - Windows 10 (but nothing else) will easily fit onto just 20GB. But I agree with above, it's worth spending a little extra to get 120GB or 240GB or larger capacity because installing the apps/games you use most often onto your SSD helps remove performance bottlenecks.
Your 600W PSU isn't really strong enough to overclock your components, but it should be sufficient for your components under load.
Your Carbide 400R chassis can top-mount a Corsair h105 (thicker 2x120mm rad) or Corsair h110 (2x140mm rad) - they cost a little more than a Corsair h100i but are also better performers.
I think a Cooler Master Nepton 280L or Silverstone Tundra TD02 or NZXT Kraken X61 would be an even better choice - more efficient cooling performance and/or less noise (and sometimes less cost) - than a Corsair h100i/h105/h110. Corsair AIOs have out-of-the-box compatability with the hole spacing and colour/style theme of your Corsair chassis ... but you would have to do your research (and possibly a little modding) to guarantee proper compatibility between a Corsair and a non-Corsair product.
Whatever AIO CPU cooler you choose, it's important to make sure you have good airflow in your small chassis so that the memory and rest of the motherboard don't overheat - I would personally mount the AIO rad as a top-exhaust, while keeping the 2x120mm front-intake fans and 1x120mm rear-exhaust fans where Corsair put them, but if temps seem a little high (especially on the GPU card) then I would upgrade the rear-exhaust fan to a 140mm and move the existing 120mm to bottom-intake.
[/Korth]
Ntwlf
Level 12
Hi vavaishnav,
I'd like to emphasize andlaw's suggestion on ram in regards to quantity. You should/will see a boost in performance overall with more ram, because with insufficient ram capacity windows will be utilizing the disk cache more by swapping files back and forth between ram and ssd/hdd if the ram is unable to hold everything put to memory.
Ram provides the fastest data rate to feed the cpu, hdd's provides the slowest, with ssd's somewhere in between put plainly.
A ram kit of 16GB @ DDR3-1866 would be a high-end match with your existing system.
Korth
Level 14
Ah, lol, you have only 4GB RAM total, I didn't notice that, sorry.
I agree with Ntwlf, you definitely need more RAM. 8GB minimum (just to make Windows happy), but 16GB would be much better if you're gaming.
A 16GB (2x8GB or 4x4GB) DDR3-1866 kit will cost you about $90-$115 USD (no sense in buying a $175 kit with same performance, unless you really like the brand). Here's the officially compatible QVL for your motherboard.
[/Korth]
vavaishnav
Thank u all for your suggestion . as per discussion I decided to buy:
corsair h105 cpu cooler other cooler not available in my country
corsair vengence pro 16gb (2 X 8gb) DDR3-1866 kit
corsair LS 240gb
Please suggest minimum requirement PSU for overclocking..
Thanx,
There isn't really a requirement for overclocking, but the Cooler Master Thunder 600W isn't the best power supply. I believe it isn't even 80PLUS certified which is a big nono for overclocking. Typical efficiency for your power supply should be around 78-82% which isn't bad, but you should still try for something better.
You need something that has high efficiency, I recommend a 650W power supply with 80PLUS silver or higher.
Do note that you don't have a very power demanding system so technically you should have no issues overclocking your system with what you've got.
