04-07-2019 11:28 AM - last edited on 03-06-2024 08:27 PM by ROGBot
04-08-2019 07:51 AM
04-08-2019 03:00 PM
ninezerofive wrote:
The main point I would be worried about is that CPU, try to sell it and get at least i5-7600k, it doesn't have to be brand new, check out some deals on ebay.
With ram, check the deals that you have going around in your region. 2x4b would be sufficient, while 2x8gb would be optimal. Since it's Intel, the actual speed doesn't matter that much. Try to look for sweet spot between Mhz and Timings. But most of the times you wouldn't feel difference betwen 2400mhz CL 16 to 3200 cl 16. Same as with the CPU, check ebay and maybe even get used one.
Although this is not a perfect solution : You can even buy 1x4gb stick for now and have the PC usable, it won't play any games, but you can browse the net and watch movies and when you gather some more cash get another 4gb.
CPU cooler is fine for now.
PSU: well if it works it works.
Fans : Don't worry too much about them, whatever you get is fine. Don't listen to elitist they will throw Noctua in your face every sentence they can, but really it doesn't matter much for the case fans. But if you wonna maximize the performance of the CPU, then I would switch the fan of your 212 cooler to this one :
https://noctua.at/en/nf-a12x25-pwm
There's nothing better than that. It's expensive, true. But even if you switch your CPU to 7600k, it would cool it well, even overclocked.
For the case it's you own preference, basically what you like best, go for it.
My personal case of choice from the midrange market is this :
04-09-2019 01:37 AM
04-09-2019 03:38 AM
04-09-2019 03:53 AM
04-09-2019 05:16 AM
04-09-2019 05:31 AM
04-09-2019 09:12 AM
