Advice regarding WiFi antenna
toxenworm
Hello
I have recently made mini-ITX build using the ROG STRIX Z390-I GAMING motherboard.
One thing which has been a focus for me is a very minimalistic computer and desktop, with as few cables as possible - and here comes my problem:
I am very sad about the cabled WiFi antenna extension as seen on this picture
I would much prefer to just have regular antenna that stick out on the back of the motherboard.
But does anyone know if I can just buy any regular antenna with the right connector? Do I need a special antenna to boost both the WIFI and the bluetooth, like the cabled antenna which came along with the motherboard?
4 REPLIES 4
xeromist
The threaded connectors should work with a standard antenna but your signal strength may not be as good. It depends on where your access point is located.
Thank you for the answer. Do you know if a standard antenna would boost the bluetooth signal as well? or only wifi?
xeromist
Interesting question. Never thought about that but I doubt you'd see a significant difference. It's designed to be low power and short range. The main reason I doubt you'd see much range difference is that it is 2-way communication and no matter how you upgrade your PC the paired device will still only be able to transmit so far.
I have no idea what the connector is for the Asus supplied WiFi/Bluetooth combo antenna is. Seems like to me that if you can find another with same connectors, it might be worth a try. https://www.amazon.com/Directional-Antenna-Connector-Wireless-Network/dp/B01MDJVPTT
Another thought. If you were to tear open on of those Asus antennas, you'd find the length of wire that is needed for the WiFi/Bluetooth frequency. After all, regardless of the fancy or bizarre style, an antenna is just a hunk of wire that is the correct length for the frequency. Build your own: http://www.hamuniverse.com/dipivcal.html
