Advice lower temps on 3900X CPU help please!!!
dja2k
Did a whole bunch of testing and reached 95 C max temps with stock Wrath Prism (yes I know it's HIGH). This is on a Asus Strixx B550-F, AMD 3900X, Crucial 3200Mhz 2x32GB .
CINEBENCH
Idle Frequency 3774MHz , VID 1.4812v (CPU TEMP), Core Voltage 1.68v (CPU-Z)
Testing Frequency 3998MHz , VID 1.2312v (CPU TEMP), Core Voltage 1.264v (CPU-Z)
My CPU Rank Score 18097 NO ERRORS, Cinebench Score from others +/- 18682
OCCT CPU
Idle Frequency 3774MHz , VID 1.4688v (CPU TEMP), Core Voltage 1.512v (CPU-Z)
Testing Frequency 4098MHz , VID 1.3062v (CPU TEMP), Core Voltage 1.328v (CPU-Z)
Results: NO ERRORS 1 HR
BLENDER
Idle Frequency 3774MHz , VID 1.4688v (CPU TEMP), Core Voltage 1.52v (CPU-Z)
Testing Frequency 3998MHz , VID 1.2312v (CPU TEMP), Core Voltage 1.280v (CPU-Z)
Results: bmw27 2m5s, classroom 5m33s, fishy_cat 2m45s,
pavilion_barcelona 5m45s, victor 10m11s
REALBENCH
Idle Frequency 3774MHz , VID 1.4562v (CPU TEMP), Core Voltage 1.68v (CPU-Z)
Testing Frequency 3998MHz , VID 1.2687v (CPU TEMP), Core Voltage 1.248v (CPU-Z)
Results: Results Hash Match! on all Tests.
PRIME95 BLEND
Idle Frequency 3774MHz , VID 1.4562v (CPU TEMP), Core Voltage 1.184v (CPU-Z)
Testing Frequency 3748MHz , VID 1.2687v (CPU TEMP), Core Voltage 1.104v (CPU-Z)
I see that different tests use different voltages to increase\decrease CPU frequencies. Can some one chime in and help if I should try a higher Offset or use a fixed Frequency. No Overclock, my friend wants to run Stock as he will later get a better CPU Cooler. Any help is really appreciated and thanks.
0 REPLIES 0
