advice for my first workstation build
fm_sam_bahadur
Hiiiiiiiiiiiiiiiiiii
This is my first workstation build.....
m using this system for hardcore 3d modelling,3d rendering,game designing & gaming also...
softwares that i use 3dsmax,maya,zbrush,cryengine & other 3d software
my budget is around 160000 (INR) indian rupee
2672.01(USD) us dollar (todays date)
yes,m going to overclock the system
m thinking about this parts:-
4820k (i have already bay this part)
sabertooth x79
corsair CMZ8GX3M1A1600C10 16gb (8*2)
gtx 770
seagate 1tb sshd
seagate 3tb hhd
seasonic SS-860XP2 860 Watts (i have already bay this part)
corsair h100i
noctua NF-F12 fans *4 (useing it on h100i as push pull)
nzxt phantom 530
dell s2440l monitor
:rolleyes:
9 REPLIES 9
kkn
Level 14
in my view i say buy.
personaly i cant see enny thing you need to change.
mabye buy SSD later to speed up boot of OS.
fm_sam_bahadur
ok thnx for reply buddy ....
kkn
Level 14
um yes, im sorry to say but i just seen some thing.
the memory, get ONE kit whit the amount of ram you need, not 2 kits ( 1 kit = 2x8gig ram chips )
and it have to be quad ( 4 ) channel ones.
There's no such thing as quad channel ram. The memory controller is quad channel. You just use regular RAM kits.
Mobo: Rampage IV BE | CPU: i7-4930@4.5ghz Hexacore | RAM: 32GB Corsair V-Pro | GPU: 4xR9 290X Quadfire | PSU: eVGA P2 SuperNOVA 1000W\G2 850W | Chassis: NZXT Phantom 820 | Cooling: XSPC Raystorm CPU Block\4xEK 290X Block\2x Laing D5\XSPC Dual Bay Res\Phobya G-Changer 1080 External Rad\Alphacool 140UT60\XSPC AX360 | Fan Con: Lamptron CW611 | Tube: Primochill Adv. LRT Bloodshed Red | 3xCrossover 27" 2560x1440 Monitors | Build Log of Insanity
so should i go with ram that i hav chosen?
another thing should i go with RAMPAGE IV or sabertooth x79
Sorry, mate, but there is such thing as "quad channel kit"... it means at least 4 modules binned/specially selected to work together at the given specs... Mixing two dual channel kits isn't always the best choice... specially not with LGA2011...
If you want a workstation, then forget the RIVBE... I would even forget the Sabertooth and get something specifically built for WS (Asus does have such boards). For those application the OP described, the system has to have as much memory as possible and also SSD(s)...
graphic
Level 11
http://www.gskill.com/en/configurator?manu=29&chip=28&model=67
http://www.corsair.com/en/memory-finder
hi, what kkn is saying is, for x79 chipset, you are required to run quad channel memory
when you visit these ram site's, ie, gskill-corsair, they have like a ram config...... where you choose
your memory to suit you motherboard, I think the xtreme is better, but that only my opinion... I curently
have the x79 formular and have been very happy, and am in the process of upgrading to the x79 black edition,
i have been running gskill 2133 mhz 16gb ram so far ( 4x4 sticks) and they have been very good, looking at getting the
CMD32GX3M4A2400C10 32GB for my new build, hope my post helps a little and good luck 🙂
fm_sam_bahadur
m cofuzed 😞
Myk_SilentShado
Level 15
Agreed with Z above me, a great WS board, 2011 Socket would be the P9X79-E WS. I'm hoping to buy one for myself this year 😄
