Adressable RGB
1981_Lucian
So the motherboard I'm looking to buy has 1x Addressable RGB connection and 2x RGB connections.
RGB is new to me, what's the difference between the addressable and regular?
ASUS ROG Strix Z390-E board
1981_Lucian
Ok so I found my answer to that first question here:
https://www.youtube.com/watch?v=MrqWyAq4L-U
Next question:
If the MB has one addressable header and the case has 3 addressable fans will I need a hub or splitter to connect each fan and/or additional addressable RGB device in the build?
