Adding a simple PCIe device to PCIex16_3?
DarvinAtkeson
I am attempting to add a simple PCIex card that will provide 7 additional USB 3.0 ports but running into problems.
I suspect there is a setting in the BIOS I need to update. Perhaps to slow the PCIex16_3 down for a generic card?
Are there BIOS settings I need to change to get a generic card to work?
Does adding a card to the third slot mess with SATA ports?
The BIOS manual doesn't say much.
Thanks
Darvin Atkeson
Maximux XIII Hero
Windows 11
0 REPLIES 0
