A2 error code on my Q-code led
Exonakaenima
Hello everyone, I've been having problems with my PC lately even though it's been up and running perfectly for more than two years now. It started a couple days ago while I was gaming, basically while I was playing and tabbing out my monitors would shut down and my fans would start to run at 100%, it happened 3 times. The first two times it happened I restarted my PC and everything was back to normal, though when my PC did it again I never got any display back.
I did some research and did everything that was possible, cleaned my RAM, tried new sticks of RAM, changed my GPU, removed the CMOS battery and put it back in, checked my monitors and cables of course, flashed my BIOS, I tried to plug a HDMI cable on the board while my GPU was removed. Nothing happened!!
While searching for any problems I checked my Q-Code LED and it says A2, which basically means that I have a problem with one of my SSD's but after checking them they're all plugged in and in their places. I have 3 SSD's and one HDD so it could've made some sense but as I said everything is fine after checking. I find it weird knowing I haven't changed anything in my PC yet that could've cause a problem as everything was working fine before that.
I'm sorry if my post is long but I'm just trynna seek some help so I can get my PC running again, thanks to whoever answers/helps me!
By the way here's my rig :
  • RTX 3090 by EVGA
  • Intel i9 10850k
  • ROG Maximus XII Hero (WiFi)
  • T-Force RAM sticks (64GB)
  • EVGA 750w gold PSU
Thanks!
achugh
Level 14
Hi @Exonakaenima are you still having issues? Have you made any progress. SSDs and HDDs can fail at anytime without you making any changes. Have you tried removing all drives except your OS drive? Does the problem still happens with 1 drive? If yes, have you tried installing OS on a different drive and did that improve anything for you?
Disclaimer: I am not an ASUS support person so my information may be incomplete. Always follow official documentation and material provided by ASUS representatives.
INTEL i9-14900K / CORSAIR VENGEANCE RGB 192GB (4x48GB) 5200 CAS38 / ROG Z790 DARK HERO / ROG TUF GAMING RTX 4090 OC / ProArt PA-602 Case / SEASONIC PRIME TX-1300 ATX 3.0 / CORSAIR MP700 PRO 2TB PCIe Gen5 / CRUCIAL T500 2TB PCIe Gen4 / EIZO CG2700X
