a simple Question of aesthetics
ERIU-OC
Hello out there,
the picture show's a rig in progress...i'm unsure about the GPU cables - leave them white, swap them to black, or do a mix?
any opinions are appreciated!
Thanks in advance!
40092
8 REPLIES 8
kkn
Level 14
perfect as is. ( my opinnion )
Razor2014
Agreed, looks good with both the white cables & tubing.
Case: CM Styker Mobo: Asus R4BE CPU: i7-4960x, Noctua DH-14 Ram: G.Skill Ripjaws Z 2133 16GB CL 9 GPU: NVidia GTX 1080ti 11GB
SSD: Samsung 850 Pro 256 & 512GB HDD: WD Black 3TB, 500GB & Seagate GoFlex 3TB PSU: Corsair AX1000 KB: Corsair K95 RGB Platinum
Monitor: Alienware AW3418DW Mouse: Corsair M65 RGB Elite, MM800 Polaris RGB OS: WIN10 64
chrsplmr
Level 18
Agreed. The White gives it that custom detailed flavor..
Black would work, but would just be vanilla.
Black and White .. ummm, NO.
Black and Red ... ok, so I'm an addict.
Very Nice. .c.
Arne_Saknussemm
Level 40
Looks good to me as you have it...replacing cables with black might leave a void down the centre if you know what I mean...the spacing at the moment white black is good.
Make sure you populate the 8 pin ATX power too! 😉 And for 3 GPUs you might want the EZ Plug PCIe power too...
Thanks all for your answers so far!
@Arne: EZ is allready connected cable is hidden and black so you can't see it, 8 Pin ATX extension cable in white hasn't arrived yet...
Build is still in progress, the picture shows a test fit in an early state of the build, to to get an idea of the look. Many materials haven'( arrived jet and will be added. Also the case painting isnt finished.
Btw i hate my smartphone by typing this...
kkn
Level 14
a smart phone isn't as smart as you think it is 😉
just look at "damn you autocorrect" 😛
first of all i wasn't sure about posting in "Build Advice" or "Case Modding", so i simply use this thread...
as time and this build goes on, i spend some thoughts about lightning and would like to hear some opinions again.
the picture below shows test fit with some lightning, to get an idea of the look of the white panel and HDD/SSD mounting.
the drives are mounted on plexi and light up with blue LED's. i used just one 30 cm white LED Strip at the top, so that the blue does not shine so bright in the surroundings. maybe a second at the bottom is needed to clean the light up even more to the end that only the edges of the plexi are shining blue.
so what are your thoughts about the white panel?
Thanks in advance!
40439
Thanks in advance!
40439
Wow...Looks amazing, if you're asking me. That white panel storage setup looks simply cool.
Keep up the good work. 😄
Desktop: Xigmatek Elysium | Rampage IV Extreme | i7-3960X | G.Skill 32Gb DDR3 2133Mhz|fastest Asus MarsII on the planet:cool: core 950Mhz| Kingston HyperX SSD 240Gb + 300Gb Intel 300series SSD + Velociraptor 600Gb + 3TB HDD | Enermax Maxrevo 1500W| 3xDell U2412m |
Laptop: Samsung 940X3G | i7-4500U | 8Gb RAM | 256Gb SSD | 13.3" 3200x1800 |
