08-06-2014
01:56 AM
- last edited on
03-05-2024
10:33 PM
by
ROGBot
08-08-2014 09:29 AM
08-08-2014 11:10 AM
kkn wrote:
the motherboard is not rated at 1.5V.
if you put XMP profile the bios will set the required voltage and mhz the ram is stated at.
if you buy a set of ram that is rated 2133mhz and at 1.65V, and you set XMP profile inside bios it will set it at 2133mhz and 1.65V.
if you buy one that is rated 2133mhz and 1.5V it will set it as 2133mhz and 1.5V.
http://www.overclock3d.net/articles/memory/how_to_manually_set_up_your_ram_speed_timings_and_voltage...
08-08-2014 05:56 PM
08-09-2014 07:51 AM
skywalker311 wrote:
The difference between the i7-4770k and the i7-4790k is that 4770k is last years refresh name haswell and the 4790k is this year refresh name devil cannon. The 4770k is clock at 3.5 GHz and the 4790k is clock at 4 GHz. There more to this year tick then last year tock. That one of the major things and that it can OC much better.
