08-06-2014 01:56 AM - last edited on 03-05-2024 10:33 PM by ROGBot
08-07-2014 02:58 AM
kkn wrote:
ram that is rated to 2400mhz can be used at 1600mhz.
it is made to run at 2400mhz max at stated voltage.
and yes you can oc 2400mhz ram higher but that will only make it hotter and it needs more voltage and you can end up damage the ram.
cpu. if you are lucky to get a good quality one you can oc it past 5ghz whit no problem
if you are unlucky it will not go past 4.2ghz.
so all in all it depends on how lucky you get when buying a cpu if its good or not.
08-07-2014 08:34 PM
kkn wrote:
you can run the 2400mhz ram from 2400 and down to 1333mhz if you want that.
08-07-2014 06:21 AM
08-07-2014 08:34 PM
HappyBuddhaman wrote:
If you're not going to OC for 5 years, don't waste your money on a K series processor. 5 years from now, with the way tech advances, everything you (and all of us) have, will be outdated. IMO.
08-08-2014 10:34 AM
Mr..X wrote:
this also means i will not be able to update for 5 years too...
08-08-2014 11:13 AM
01 Wolverine wrote:
Hi X the 4790k can run turbo@4.4 mhz. You can play at turbo and oc at your leisure
and the next gen intel chip Broadwell will also fit your m7f motherboard
so you will be set for awhile
08-08-2014 12:28 AM
08-08-2014 09:13 AM
kkn wrote:
if you drop voltage you will get unstable too. if you have fans in the roof have it as intake.
that way the air will help cool down the heatsink on them.
