A good strong multipurpose gaming system?
dlf
  • Purpose of System: Gaming, browsing internet, watching videos. But mostly for gaming. I may want to do folding@home
  • GPU Setting: Quite high, if not ultra (eventually, for when I get a new monitor)
  • Budget: @ Around $1300 - $1500 (or so)
  • Country: USA
  • Reuseable parts: Can't, see below (current specs) as to why (prebuilt)
  • Overclocking: No
  • Monitor: Currently 1680 x 1050 (22 Inches) - I eventually want HD (Between 23 - 27 inches)
PCPartPicker part list / Price breakdown by merchant / Benchmarks
Total: $2055.16
(Prices include shipping, taxes, and discounts when available.)
Current specs:
  • Case: No idea (although it is a HP slimline, gray) - that should give some idea of the sort of case.
  • Motherboard: Asus A8N-BR (Pyrite) (1 PCI, 2 DDR2 DIMM, Audio, Video, LAN, IEEE-1394)
  • Motherboard Chipset - nVIDIA GeForce 6150 LE, AMD Hammer
  • Power Supply: No idea (but it's less than 100 watts, I think)
  • Processor: DualCore AMD Athlon 64 X2, 2000 MHz (10 x 200) 3800+
  • CPU Cooler: A fan
  • Memory:
  • - DIMM1: Kingston 1 GB DDR2-533 DDR2 SDRAM (5-4-4-12 (at) 266 MHz) (4-4-4-12 (at) 266 MHz) (3-3-3-9 (at) 200 MHz)
  • - DIMM2: Kingston 2G-UDIMM 2 GB DDR2-667 DDR2 SDRAM (5-5-5-15 (at) 333 MHz) (4-4-4-12 (at) 266 MHz) (3-3-3-9 (at) 200 MHz)
  • Hard Drive: 250 GB ATA drive
  • Optical Drive HL-DT-ST DVDRRW GSA-H20L ATA Device (DVD+R9:8x, DVD-R9:4x, DVD+RW:16x/8x, DVD-RW:16x/6x, DVD-RAM:5x, DVD-ROM:16x, CD:48x/32x/48x DVD+RW/DVD-RW/DVD-RAM)
  • OS: Windows 7 Home Premium 32 bit
What I wanted from the System
- Hardware
  • USB 2.0 & 3.0 ports
  • Firewire & or eSata port
  • Support for DVI/HDMI (display port?) - either from the motherboard or from the GPU
  • Quad Core
  • Bluetooth - so I can hook up PS3/WII controllers
- Software
Windows 7 Ultimate 64 bit
Folding @ Home
-- Gaming Software
  • (Heroes of) Might & Magic
  • Diablo 1-2 (LOD)
  • SimCity 2/3/Unlimited/4/Rushour
  • The Sims 1/Expansions
  • The Sims 2
  • The Sims 3
  • Warcraft 1 (If possible) /2/3
-- Steam
ID software
  • - Commander Keen
  • - Doom (will run Classic Doom 3 as well)
  • - Hexen/Heretic
  • - Quake (Ult Quake) (all)
  • - Rage
  • - Wolfenstein
  • PopCap Games
  • - Bejeweled (all)
  • - Peggle (all)
  • Bethesda
  • - The Elder Scrolls
  • -- Morrowind (may try MorrOblivion & Skywind)
  • -- Oblivion (will try using the skyrim engine)
  • -- Skyrim (plenty of graphical mods and other mods)
  • - Fallout
  • -- 1-3/New Vegas
  • Valve
  • - Portal 1/2 (plenty of custom maps)
  • - Half Life (if it will run)
  • -- Along with the fan remake
  • Misc Title
  • -- Batman: Arkham Asylum/City
  • -- Deus Ex: Human Revolution
  • -- Dragon Age: Origins
  • -- L.A Noire
  • -- Legends of Grimmrock
  • -- Torchlight 1/2
  • -- Metro 2033 (& Last Light)
  • -- Sniper Elite (2?)
  • -- Space Quest & King's Quest (if I can run them)
  • -- Bioshock 1/2(/Infinite?)
  • -- Sonic Generation-
  • I may try to emulate games up to the PS2/Wii era.
Power Supply
- @AT most 750 watts
- At lest 80+ Silver
- Semi or fully Modular (preferably fully)
MISC thoughts
  • Eventual dual monitor setup & one be Full HD.
  • 23+ Inch Widescreen (absolute max 27)
  • Thinking of eventually getting a Asus PB278Q 27.0" Monitor
  • I will not overclock. The CPU chosen was cheaper than the NON "K" edition. By like $30 or more.
  • Also I DO live in TEXAS, specifically Dallas, it can (in the summer) get upwards of at lest 40 degrees Celsius (~105 F) here. I don't think the heat outside and the overclocking of the CPU would be very good.
  • Also as to why a gigabyte boards, the asus board I was look @ although cheaper, seemed like it was having issues. The gigabyte also has bluetooth (which I want) and a few additions the asus didn't have.
Thank you, merci, gracias, domou arigato . . .
10 REPLIES 10
Arne_Saknussemm
Level 40
Stanford recommend turning HT off on a 4 core processor....4 plain cores work better at the moment than if you present 8 cores...so forget HT if folding on your CPU is your main thing....
http://folding.stanford.edu/Spanish/FAQ-SMP#ntoc15
