970 Pro Gaming won't show M2 SSD
ilovefilms
I finished a new build with a 970 Pro Gaming / Aura motherboard. The OS is on a 500 GB SATA SSD but I added a 1TB M2 for storage. The M2 is not showing up in the bios or windows. I have gone through all the settings in the Bios to try to add it but have had no luck. Am I doing something wrong? I would hate to return this M2 and have to go with a standard drive if I had to. Thanks in advance for any advice.
0 REPLIES 0
