800$+- PC build
Akreontage
Hey all!
My friend asked me to help him build new not very expensive PC. His budget is 800~ bucks. I don't have any idea where to start with these limits.
Hope you can help me! 🙂
Upd:
Beta version. 😄
Corsair 200R
Asrock 970 Extreme3 r2.0
Fx-6350
Kingston 8gb 1600mhz 9cl
WD black 1tb
Corsair cs650m
Gigabyte 650ti boost
Will it be ok to use cs650m?
DVD-RW
Corsair Carbide 500R | Asus Rampage IV Formula | i7-3930k 4.4Ghz | Corsair Vengeance 32Gb 1600Mhz 9cl | Gigabyte GTX 1080 G1 Gaming 8G | Samsung 850 Evo | WD1002FAEX | Antec HCP-1200 | NZXT Kraken x62
Chino
Level 15
A $800 budget is enough to build a pretty nice gaming computer with top notch components. The following build is a good start for him to get into PC gaming. It should play most of the modern games with ULTRA settings at 1080p without any problems.
CPU: Intel Core i5-3570K 3.4GHz Quad-Core Processor ($225.98 @ Newegg)
Motherboard: Asus P8Z77-V LK ATX LGA1155 Motherboard ($114.99 @ Newegg)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-2133 Memory ($59.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($58.13 @ OutletPC)
Video Card: Asus GeForce GTX 760 2GB Video Card ($249.98 @ SuperBiiz)
Case: Rosewill Challenger-U3 ATX Mid Tower Case ($24.99 @ Newegg)
Power Supply: SeaSonic G 550W 80+ Gold Certified Semi-Modular ATX Power Supply ($85.99 @ Amazon)
Total: $802.05
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2013-12-06 09:58 EST-0500)
Akreontage
The problem with these parts is... Well they are much more expensive here in EU. ) So it's not at 800 bucks at all. But thanks anyway.
Antronman
Despite being new to the community, the more and more I've been looking at preformance and cost, intel processors are looking more and more overpriced and useless. The FX - 6350 is a good choice, but it is a little bit weak. You get snag an FX - 8350 for almost the same price tag. (At least here in the US) I wouldn't go with a Gigabyte GPU, and instead I would look for an EVGA, an ASUS, or a PNY.
Say hi to the next generation.
Peace is a lie, there is only Passion
Through passion, I gain strength
Through strength, I gain victory
Through victory, my chains are broken
The Republic of Gamers shall free me
