I did install the radiator in front of my pc (top is no option because cpu AIO).
Removed the 2x 140mm i used for front intake, and installed the 2x 120mm radiator fans instead.
Then wanted to put the 2x 140mm on the bottom, but found out its max 120mm bottom of my case.
The radiator fans are idle most of the time, and now i have no intake fans anymore.
Would it be possible to switch them?
Can i replace the stock 120mm on the radiator with the 140mm's i have?
Corsair iCUE SP140 RGB Elite Performance 140mm PWM Fan - Dual Fan Kit with Lighting Node Core
Then i have 140mm in front again and could use the 120mm's bottom as intake.
I can immagine the hardware is designed for use with these specific fans in mind so is it possible? And a good/bad idea?
Or was it wrong i removed the 140mm front intake fans in the first place?
And should i have installed the radiator with it's 120mm fans behind it.
So fans on both sides of the radiator?
If so i just put them back and buy another set 120mm for bottom intake.
Sorry if this are stuppid questions but i have no experience with anything else then air cooled builds and really could use some advice.
