600t water cooling options
SKOONJar
I recently finished building my new computer in my 600t case. Naturally as any enthusiast with anything there baby is never finished. So I'm already planning my next upgrade. Its a custom water loop. Never touched water cooling before and its going to be a while before I make the purchase so heres my question. What are my options for radiator placement(without removing any hdd cages or making disk drive bays useless minor modding is ok within reason though dont want to tear my new case apart beyond repair(new to modding also)). And what are the best companies to be looking at for reasonably priced goods. My ideal loop would include my cpu and a gpu no ram or chipset cooling. Suggestions and price ranges are very welcome!
Thanks in advance!
20 REPLIES 20
kkn
Level 14
rad thicknes, where to put it, how big can it be ( 120 or 140 fan slots ), what are you gona cool++
bay res, stand alone res, pump/res combo+++
Zka17
Level 16
Well, I think that case isn't optimal for a custom loop water cooling... - not hopeless though...
If you don't want to remove the HDD cage to make some room, then your options are pretty limited... - I would go then with a closed loop system for the CPU... or, go with an external rad setup, then you will be able to cool everything in that system...
You perhaps can find everything you need for watercooling on the EKWB's website...
Also I said I can mod the case but not a lot dont want to hurt the structural integrity of the case. I'm open to suggestions
SKOONJar
It will be cooling a 3770k and a 7950.
kkn
Level 14
a 360 rad would be sugested or a 460 if OC'd ( can do 2 240 or 1 360 and 1 120 ) all up to you.
You have any examples as to how I would mount them?
Zka17
Level 16
I would say go with an external radiator... you simply can not mount enough raditors in that case to cool everything...
A Watercool MO-RA3 9x120mm or 9x140mm would do the job... 🙂
kkn
Level 14
That looks amazing but that pricetag puts a yowzers in my trousers does it come with water blocks atleast?
