5939K after upgrading hotter?!!
nl_wouter_nl
haay, i have the 5930K.GTX1080 all watercooling, and after upgrading my pump reservoir i got high temps, From EK-DCP 4.0 PWM X-RES to XSPC D5 Photon 270 Reservoir/Pump Combo/D5 i got Higher temps. i buy things for total 1000 euros, for fixxing the problem, but still hot temps. not extreme hot but to hot for watercooling i think...anyone a fix?
Before: idle 20c/24c
Before: Load 33c/34c
After: idle 30c/34c
After: Load: 43c/46
this is what i tryed:
exit the air,
new cpu block ekwb evo x99
second pump my old EK-DCP 4.0 PWM X-RES
few times other loop.
new cool paste ceramique 2 the new ekwb paste for my new cpu block and and Noctua's NT-H1
new fans Air Series SP120 PWM High Performance Edition High Static Pressure 16 fans 8 up rad 8 down rad *hot air out* << - >>** not push pull >>->>
new fittings
motherboard waterblocks* RAMPAGE V EXTREME/U3.1* EK-FB KIT ASUS R5E - Acetal
gpu/cpu waterblock cleaning for dirty
running at stock speed and stock voltages and overclocking from 3.5GHz 1.152 to 4.5GHz to 3.8v
buying green sleeved cables from cable mod.
And the last order for this week. is 2 new radiators
Because my rads rightnow is this effect:
https://www.google.nl/search?q=radiator+broken&biw=1920&bih=901&source=lnms&tbm=isch&sa=X&ved=0ahUKE...
That pins or something are all broken/askew on all the 2 rads.
so i get this friday my 2 new EK-CoolStream PE 480 rads. if thats not helping my problem, only thing wat is over, are my cpu or my motherboard.
And idont know but my Corsair AX1200i is hotter then normal...
Hopefully is this enough info.
if not, ask me... 🙂
Here my full system specs:
Case: Corsair Obsidian 900D
Supply: Corsair 1200i
CPU: i7-5930K
CPU Block: EK-Supremacy EVO BLACK Edition
GPU 1: NVIDIA GTX 1080 FOUNDERS EDITION
GPU 1 Block: EK-FC1080 GTX
Pump 1x: XSPC D5 Photon 270 Reservoir/Pump Combo/D5
Rad 2x: EK-CoolStream PE 480 Radiator
Motherboard: Asus Rampage V Extreme / u3.1
Ram: Corsair Dominator platinum 16 GB (8x4GB) 2800 DDR4 * 32GB Ram* 16-18-18-36
samsung 840 Pro SSD 128 GB + 2000 GB (HDD) + 3000GB (HDD)+ 4000GB (HDD)
Monitors: Tripple Screen Benq XL2411Z 144HZ
XSPC D5 Aluminium Screw Ring Black x1
LED 5mm Ultra Helder UV x1
Feser Tube UV - HighFlow - 3/8 ID - 1/2 OD - ACID GREEN x4
EK-Ekoolant EVO UV Lime GREEN premix 1L x4
EK-AF Angled 90 degree G1/4 - Black Nickel x6
Bitspower G1/4 Silver Shiny IG1/4 Extender 30mm BP-WTP-C63 x1
Bitspower G1/4 Silver Shining IG1/4 Extender 15mm BP-WTP-C60 x2
10MM (3/8 ID - 1/2 OD) Schroeffitting 90 graden - 2x schroef - Black Nickel x4
EK-FB KIT ASUS R5E - Acetal MOSFET & SB Waterblocks
5x EK-AF Angled 90 degree G1/4 - Black Nickel
RAZER BLACKWIDOW CHROMA Keyboard
Razer Tiamat 7.1 HeadSet
RAZER OUROBOROS Mouse
Sooo Please Can Someone Help me getting me out of hell ???........ lol
thank you in advance!!!!!!!!!!!!
btw I'm out of money rightnow LMAO...
kkn
Level 14
custom WC cost a great deal.
what is the airflow in the case?
have you put on new TIM on the CPU?
are you shure you have got out all the air in the loop? even in the rads?
Arne_Saknussemm
Level 40
