3 pin RGB strip compatibility with these newer boards? Is there a list somewhere?
scgt1
So I have two boards that have the old easy to sort and find 5050 4 pin headers. I'm updating my fiances computer and using the H370I which to my surprise has a 3 pin header which kinda stinks because I have a spare set of led's from an older Hue that I was going to use until I found in the specs most of these newer boards may or in my case may not have the 5050 header anymore and instead has a 3 pin.
So what strips are everyone using that are compatible and do they actually hit fully white? I'm finding some online that are 3 pin but still look bluish. Please only list strips that are magnetic. That 3m tape is a joke and doesn't hold.
0 REPLIES 0
