2014 PC build
ACE90
Hello lads and lassies.
I'm planning on my PC build for 2014 and would like to hear what some of you think. Below is the list of parts and feel free
to comment and offer advise and/or warning :).
Case: Cooler Master HAF XB (EVO version if it comes to sweden)
Case Fans: 2x 140mm Cooler Master BC Red LED (front intake)
1x 120mm Cooler Master Jetflo Red LED (rear exhaust)
1x 200mm Cooler Master Megaflow Red LED (top exhaust)
MB: Asus Maximus VI Formula or Extreme (haven't decided)
CPU: Intel i7 4770K @3.5 GHz
CPU Cooler: Cooler Master v8 GTS
GPU: 2x Asus R9 290X (Matrix version if/when available)
RAM: Corsair Vengeance PRO Red 32GB @ 1600MHz
SSD: Corsair Force GT 120GB
HDD: WD Caviar Black 4TB (type FAEX)
PSU: Corsair AX860W Platinum (Preferably a 1200 if it fits)
OS: Windows 7/8,1
What is the Republic's Opinion?
Edit 21/12-13: Hello again. I'm now considering swapping the CM case for a corsair Carbide Air 540. What do you think? Any suggestions for cases? I'm looking for a box-type case to have standing on my desk.
Edit 5/1-14: Brainstorm: A Rampage IV Black Edition with Intel i7 4960X in a Corsair Air 540?
14 REPLIES 14
Antronman
Level 11
It is not worth getting any SSD series aside from the Samsung 840 Pro series. srsly. The benchmarks make all others SSDs laughable at. For the cost of pretty much any other SSD on the market right now, you get ludicrously faster benchmarks. The Samsung 840 Evo series is a low-cost alternative, but the best speed, and best cost/performance is found at the 840 Pro series. No other SSD is worth buying in my opinion. Unless there is a faster SSD on the market that I am unaware of. Keep in mind larger capacity SSDs are almost always faster. And that 128gbs of storage will only really be enough storage for OS and maybe one big game you always play. (Aside from Team Fortress 2 of course.) 256gbs is good, and the 512gb 840 Pro is obviously best.
Say hi to the next generation.
Peace is a lie, there is only Passion
Through passion, I gain strength
Through strength, I gain victory
Through victory, my chains are broken
The Republic of Gamers shall free me
Krab19
I would also say to get a larger SSD. Although 120GB is enough for the OS, you'll find that it fills up pretty quick with other programs/games. Between the two motherboards, I would say the Formula.
Yes, yes, yes! I absolutely love my Air 540, it's an amazing case! If you do decide on the CM V8 GTS, then you'll have room for either 2x120mm or 2x140mm fan up top. Or if you decide on something like the H100i, then you'll have lots of room for that too. I do not think you can go wrong withe Air 540 😄
Lana:
Asus Maximus VI Formula | Intel Core i7 4770K | Corsair H100i
ASUS GTX 780 DCII | Corsair Vengeance Pro 2x8GB 1866 Mhz | Corsair Air 540
Samsung 840 Pro | Seagate Barracuda 2TB | Corsair AX760
Lovely. I am leaning towards the H100i :).
Nice :). I'm leaning towards the H100i for the moment. Probably going to end up with that 🙂
Antronman
Level 11
If you go big, then go with a Corsair Obsidian series. I personally love the Graphite series, for its smooth, modern look. But big builds need beef. An Obsidian 900D or 800D are great. But if you want to upgrade to a custom WC loop? The Phantek Enthoo Primo Ultimate. Just look it up.
