I wanted to know can we install 2 gtx 3090 zotac trinity gpus in the crosshair 8 , Do i have to use a 2 way nvlink or 3 way . Can some one pls confirm .
Also if i do install 2 gpus - How many M2 - Gen 4 NVME can i run with the system
Casing would be a Corsair 680x , Just want to confirm would i need a 2 way / 3 way or 4 way nv link .
Silent Scone@ROG wrote: See NVIDIA's diagram for measurement.
this picture is correct had the gpu been a complete 2 slot soloution but its not its 2.5 slot , hence my question again how can i fit a 2 slot nvlink to the 3090 when 1 gpu is 2.5 slot .
