12+ case fans
Laing1982
I'm going to a 900d, i'm looking to get 8 fans for 2 radiators, and replace the stock ones, what is the best way to connect all these fans? The Corsair link commander is £50 and controls 5 fans, surely there must be a cheaper way?
Thanks,
Paul
Corsair 900D / Corsair AX1200i / AMD FX-9590 @ 4.7ghz / ASUS ROG Crosshair V Formula Z / ASUS ROG 7970 Matrix Platinum Crossfire / x2 EK Coldstream XTX 480 Radiators / x2 EK 7970 Matrix Waterblock / EK Supreme LTX CPU Waterblock / EK ASUS C5F-Z Waterblock / XSPC D5 Photon 270 Reservoir/Pump Combo / Corsair Vengeance 2133mhz / Corsair Vengeance K70 / Corsair Vengeance M65 / 120gb SSD & 2tb HDD
5 REPLIES 5
HiVizMan
Level 40
I would use the 4 pin Molex connectors and expanders.
chrisnyc75
Level 12
If they're PWM fans, the Swiftech splitter is a good solution:
http://www.frozencpu.com/products/20988/ele-1196/Swiftech_8-Way_PWM_Cable_Splitter_-_SATA_Power_8W-P...
If they're not PWM, either buy PWM fans or wait a few months for Phanteks to release their PWM fan hub/splitter.
Then connect each hub/splitter to either a pwm header on your motherboard or a channel on a rheobus fan controller (pay attention to how much voltage each channel can push)
Asus RIVBE • i7 4930K @ 4.7ghz • 8gb Corsair Dominator Platinum 2133 CL8
2xSLI EVGA GTX 770 SC • Creative X-Fi Titanium • 2x 840 SSD + 1TB Seagate Hybrid
EVGA Supernova 1300W• Asus VG278H & nVidia 3d Vision
Phanteks Enthoo Primo w/ custom watercooling:
XSPC Raystorm (cpu & gpu), XSPC Photon 170, Swiftech D5 vario
Alphacool Monsta 360mm +6x NB e-loop, XT45 360mm +6x Corsair SP120
EnthusiastBuild
Level 12
I would use those ones, im using them in my 900 D build: http://www.frozencpu.com/products/12594/cab-429/Phobya_Y_Cable_Splitter_-_3-Pin_to_4x_3-Pin_-_UV_Red...
Cheers
CORSAIR 900D
ASUS MAXIMUS VI FORMULA
INTEL I7 4770K @ 4.5 GHZ
CORSAIR DOMINATOR PLATINUM 16GB @ 2400MHZ
SLI EVGA GTX 780 SC ACX
SSD SYSTEM: CORSAIR FORCE GT 120GB
SSD APPS: CORSAIR FORCE GT 240 GB
HDD STORAGE: WD BLACK 2TB
CORSAIR AX860I PSU
CORSAIR H100I 4 x SP120 HP
Laing1982
Cheers guys! Very helpful 🙂
Ordered 7970 matrix waterblocks from USA today (sold out in UK) and 900d ordered, project started 🙂
abvolt
Level 11
That Swiftech splitter works really great I've got 2 .
Current: MSI Xpower Gaming Titanium | 7700K | G Skill Ripjaws V 3000 16Gb | 960 EVO 500Gb | Intel 730 480Gb | Seasonic 1000 Platinum |
NZXT X62 | Acer XB270HU | EVGA 1080 ti FTW3
Secondary: R4BE | 4930K | G.SKILL 2400 16GB | Corsair AX 1500i
Intel 730 240GB + 480GB | EVGA GTX780 ti sli kpe | Custom H20
