Charging problem
AhmadsalahoOoZ
After the last bios update i've noticed that my Rog Ally stops charging after about 30mins of playing any game on Turbo mode...
The device gets too much hot
Only goes back to charging after i cool it in front of the AC or restarting the device
Notice that i'm using the original charger
1 ACCEPTED SOLUTION
Accepted Solutions
Anbby_ROG
Customer Service Agent
Hi All,
Thank you for your patience. BIOS 339 has been released through Armoury Crate SE.
Please try updating to BIOS 339. If you have any concerns after the update, please do not hesitate to let us know. Thank you.
16 REPLIES 16
Anbby_ROG
Hi @AhmadsalahoOoZ ,
Could you please confirm if your current BIOS version is 338? If so, please try rolling back the BIOS version to 337 using EZflash and test if the issue persists. Thank you.
Yes it's bios 338
But could you explain how to downgrade to 337 ??
Youlz
Same problem
Anbby_ROG
Hi All,
Hi
Unfortunately, the problem of not charging the device's battery and not using the adapter after the device's temperature has increased has not been solved (Version 339)
Please solve this problem
Thanks
Anbby_ROG
Hi @Sajadkharestani ,
Due to the need for your personal information.
I have sent you a message, please check✉. Thank you
Brother Has Your Problem Been Solved I Have The Same Bios 339 And The Charging Problem Is Still There
I restored the default bios settings, that solved the problem.
