z790 extreme anime matrix is slow
hashemjd
hello everyone this is my very first post
i been wondering if anyone had that issue where the anime matrix movement is slow or like stuttering sometimes
i used to use the z690 extreme no issues like that
is there anything i can do to improve it ?
AlexWhales
Welcome to the community! It’s great to have you here.
It sounds frustrating dealing with stuttering on the Anime Matrix. A few things to try:
1. Update Firmware & Drivers: Ensure your motherboard and Anime Matrix software are up to date. Sometimes updates fix these performance issues.
2. Check Resource Usage: High CPU or GPU usage can cause stuttering. Try closing background applications to see if performance improves.
3. Adjust Settings: In the Anime Matrix software, try lowering the animation's complexity or frame rate to see if that smooths things out.
4. Power Settings: Ensure your system's power plan is set to high performance to prevent any throttling.
Hopefully, one of these solutions helps smooth out the movement!
