What Graphics Card Do I Need For World Of Tanks?
Mankz
If you’re tempted to get into Guinness World Record holding super-MMO, World of Tanks, then we’re here to help! ROG has co-worked with Nvidia to produce the following tool to help check whether your system is up to the task or which graphics card is the upgrade path for you.
http://rog.asus.com/221182013/graphics-cards-2/what-graphics-card-do-i-need-for-world-of-tanks/
7 REPLIES 7
sectionate
Level 12
if it was just to bench then rog ares II http://www.asus.com/ROG/ARES26GD5/ - If not then a good 500 series nvid or 6k series ati. I dont believe in benchmark/marketing/sales review sites. Actually to bench I wouldnt need that ROG because
ATI Radeon HD 5700 Series meets the game's recommended specifications.The Minimum system requirements are weak, my 965 would handle it fine.
Crosshair IV 1090T 4093.7 - Crosshair V FX - 8350 Batch # 1243PGT 4.422MHz - 4816.08 MHz 1.5v - GSKILL F3-14900CL9D-8GBSR(x2)1087.6 11-12-10 1.5volts - ViewSonic VX2439wm - Acer GD235HZ - SyncMaster P2350 - PowerColor Red Devil RX 480 8GBD5-3DH/OC - Current Mode: 5760 x 1080 - (retired) ASUS GTX660DC2O2GD5 - Nvidia 3D Vision Wired - HAF 932 - Corsair HX850 - Corsair H100i - latest quakelive.com - Day thirteen 60fps - as always I'm powered by Futurelooks.com
Mystery-_-Man
I don't imagine it would need very much, but I have no experience with that game, so no clue there.
Lockques
Im using Nvidia Gtx500 series with it and it works fine:)..
Mobo: Asus Crosshair V Formula-Z
Processor: AMD Phenom II X4 965
Ram:Corsair Dominator Platinum 16GB
Graphic Card:Asus GTX 670
PSU:Corsair AX1200i
Cooling:Corsair H80i
CraZeeY
With every thing maxed I get 40-60 fps on my 7970
but it depend to your budget
Next Build
- AMD Vishera FX-8350
- AMD Radeon HD 7870
Adhy_Dharma_FN
I recommend you to use "AMD RADEON HD 7970" It's great
Next Build
Mandangalo18
It told me that a way for me to upgrade was to get the 660 ti. Working as intended?
CPU: i7 7700k | GPU: Titan X (p) | PSU: Seasonic 1000W Platinum | MB: ASUS Maximus IX Extreme | SSD: Samsung 960 evo | HDD: WD Caviar 160GB | RAM: Gskill 32GB 3200mhz | OS: Win 10 64bit Home
