Starcraft 2 HELP plus Laptop.
Lincoln656
Hello Guys!
I'm just wondering what is the problem of my Starcraft 2 to my new Asus ROG G750JM
By the way this is the link for my laptop just bought it 3 days ago.
http://www.amazon.com/G750JM-DS71-17-3-inch-Gaming-GeForce-Graphics/product-reviews/B00IKF2H12
Just click it to see product details and to see specs.
Anyway to start I already experience the BSOD here to my laptop that is day 1. But an update with the Nvidia solves it. Cause i don't experience it anymore only one time 🙂
Ok the problem, the Starcraft 2 in Ultra or all max out its good I'm getting a good fps. But im just wondering why do i get a lag after 30 to 40 mins? Nether lots of units or no unit at all I experience the lag in in-game.
This is what i notice
- When battery mode game doesn't perform well even you set it to max performance (i think its because it needs a lot of power 🙂 anyway i just plugged it in)
- Even at fresh start when i do the alt tab and resume it, It gets laggy for the whole game. So i need to exit the game and re open it, by doing that i get the game running fine again.
So that's all what i notice and pardon me if Im not good explaining things and for my english 🙂
Anyway anyone out there knows the problem for my game and laptop? and also i already use the gpu tweak too bad its not the same with the other gpu tweak out there. And also i dont think its an overheating issue cause the gpu temp is 29 while the processors 25 to 30
ok that is all hope you help me
0 REPLIES 0
