Rampage III Extreme unstable?
geeknine
Hey guys,
I have a Rampage III extreme that I have been fighting with for a while now. it seems that after a while, or updates or any real changes to the OS the OS becomes unstable on reboot and corrupts itself. I have tried different versions of WIndows 7 and 8 and even XP just for the hell of it. They all do the same thing, pretty much have to reinstall the OS and application after 3 months. I have recently started taking an image with ReDo backup and recovery to speed to process.
I have tried different sata ports and HDD and SSD's with no difference. I am running BIOS 1502.
I am running the Sata is RAID mode currently but have had persistant issues in AHCI and IDE as well.
Ideas on why this is happening?
Thanks,
Arne_Saknussemm
Level 40
You could memtest86+ the RAM....if ram is not functioning 100% properly it could corrupt a fresh install and then keep corrupting the OS...
TheSurroundGame
Go back to all default settings and work from there. Try the original BIOS that your mobo came with.
\Project\ Triple Surround Fury
•Mountain Mods Ascension case•
•i7 920 D0 @ 4.0GHz•
•ASUS Rampage III Extreme•
•Mushkin Enhanced Ridgeback 3 x 2GB DDR3 1600MHz (6-8-6-24-1T)•
•PNY GTX 670 3-Way SLI•
•Crucial M4 256GB•
•Windows 7 Home Premium 64•
•(2)Corsair HX1000 1000W PSUs•
•(3)ASUS VW266H 25.5" 1920 x 1200 monitors in Nvidia Surround•
YouTubeGoogle PlusFacebookBlogger
