Question Advice on upgrading graphics card is enough for gaming or not
joris777
I want to upgrade my normal PC to a gaming PC, but my budget is low. I was thinking, can I just change the graphics card to make it suitable for gaming? Also, could you suggest some good budget-friendly graphics cards that would work well for gaming?
4 REPLIES 4
Nate152
Hello joris777
What motherboard, cpu, memory and power supply do you have?
What graphics card are you currently using?
I’m currently using:
  • Motherboard: ASUS Prime H310M
  • CPU: Intel Core i3-8100
  • Memory: 8GB DDR4
  • Power Supply: 400W
  • Graphics Card: ASUS ph-gtx1660-06g
Nate152
Thank you
With a 400w power supply, you'd be better off keeping what you have. Looking at say the RTX 2060, it requires a minimum of a 550w power supply.
The PC Bottleneck Calculator shows a 42% bottleneck with an i3-8100 and RTX 2060. - Bottleneck Calculator | PC Builds (pc-builds.com)
Most games today recommend 16GB of memory, upgrading to 16GB of memory may help if you're having performance issues.
frelancesage
Yes! Upgrading the GPU is a fantastic budget move for gaming! Check out benchmarks online to see which graphics card best fits your games and wallet. Used options can also be a steal! Good luck on your gaming PC journey!
