PC Freezes Randomly while gaming No error code for QCodes
MrGlass
I currently built a new computer and updated my my board bios version to 1501 and upgrade my ram to DDR5 2*32 at 6800mhz. All of sudden whenever I game my computer freezes and I cant force close task the application I have to hard reset my computer pressing the restart button on my tower.
Does anyone have a fix for this? I know this might be a know issue with Asus motherboard?
My Specs:
Asus z790 Hero Bios 1501
i9 14900k
Asus 4080 OC edition
GSkill trident Z 2*32 GB 6800mhz
Corsair 1500i power supply
Custom Water cooling loop with a 360 rad and 480 rad on a corsair d5 pump.
Possible solution I found on this website forms page however it did not fix my issue:
POSSIBLE SOLUTION FINALLY:
Sync All Cores in Bios
- Advanced Settings - AI Tweaker
There is an option "Performance Core Ratio"
- Select "Sync All Cores"
= this is considered a type of overclock. However it just matches the voltage, etc. to all cores and prevents power fluctuations between the cores. I have actually noticed a significant performance increase in my FPS while gaming with the same temps as before with no adverse affects. This solution has solved many peoples random freezing issues at idle or under a low load, such as a web browser being open. I do still believe this is a motherboard issue from Asus but so far I have not had a freeze after doing this.
Another possible option I have heard of, is disable the c-state. I do not currently have instructions on this.
Even if this resolves my issue I will be avoiding Asus products in the future, do to the fact the quality and quality control and service has been going down the last few years and they are clearly just after our money now and don't care about anything else.. Here are two videos for a deeper explanation.  Hope this helps
JayzTwoCents - YouTube - I'm sorry ASUS... but you're fired!
https://www.youtube.com/watch?v=wZ-QVOKGVyM
Gamers Nexus - YouTube - ******* ASUS: Overvolting CPUs & Screwing the Customer
https://www.youtube.com/watch?v=cbGfc-JBxlY
The last several years have proven that ASUS is anti-consumer and lack serious quality control. Enough so, that we can no longer support the brand or allow them to be one of our trusted sponsors. Get your JayzTwoCents Merch Here! - https://www.jayztwocents.com ○○○○○○ Items featured in this video ...
Sponsor: Deepcool AK620 Zero Dark on Amazon https://geni.us/apRI9Q ASUS' actions relating to the Exploding Ryzen CPU debacle are disgraceful and abrasive to the trust that the brand has earned. ASUS has demonstrated clearly it wishes to not only avoid supporting users, but actively engineers ways
0 REPLIES 0
