Need opinions on head sets
DDustin
I'm picking up a temporary headset until I can afford better. I can only pick between 2 because I have a credit at my school book store for a couple hundred from a returned book. My options are the Logitech H390 and Skullcandy Lowrider. How do these two compare? I'm more worried about sound quality than comfort or anything else. Like I said these are my only options until probably this summer.
Thanks a lot for the input.
Dustin
G74SX-3DE
I7-2670QM Processor 2.2-3.1GHZ
3x4gb DDR3 1333mhz RAM
Crucial M4 256gb SSD + Stock 750GB 7200.4RPM HDD
nVidia GeForce GTX 560M 3GB vram GDDR5 DX11
5 REPLIES 5
abvolt
Level 11
Skullcandy gives you a nice choice of cool colors thats a plus..
Current: MSI Xpower Gaming Titanium | 7700K | G Skill Ripjaws V 3000 16Gb | 960 EVO 500Gb | Intel 730 480Gb | Seasonic 1000 Platinum |
NZXT X62 | Acer XB270HU | EVGA 1080 ti FTW3
Secondary: R4BE | 4930K | G.SKILL 2400 16GB | Corsair AX 1500i
Intel 730 240GB + 480GB | EVGA GTX780 ti sli kpe | Custom H20
Nate152
I think I would go with the skullcandy just because the Logitech headset is USB. Never been a fan of USB headsets.
LukeeVassallo
Regarding sound quality they seem to be both the same, however, like Nate152 said, I prefer jacks to usb for audio.
| Maximus V Formula | i7-3770k | 16Gb Dominator Platinum | GTX 780 | Force 240Gb | 2TB Caviar Green | Obsidian 650D | AX850 | H100 | 24" LED VS247H |
DDustin
I thought USBs were the big thing right now? Why are audio jacks better?
Does anyone have any personal reviews of either of them?
How do either of those stack up with other gaming head sets? What's most people using?
G74SX-3DE
Antronman
The advantage of audio jacks is that you can later on upgrade your build by adding a soundcard (those only work with audio jacks) which will greatly improve your sound quality. There is no most used headset, but Corsair is generally considered as the best creator of gamin peripherals.
Say hi to the next generation.
Peace is a lie, there is only Passion
Through passion, I gain strength
Through strength, I gain victory
Through victory, my chains are broken
The Republic of Gamers shall free me
