need help please
immaturegizzmoe
Hello everyone, I wanted to make my gaming PC stronger so I bought a second card and setup crossfire but some things not right. I have a
I7 3770k CPU, a maximus 5 formula board with 16 gigs of g skill 2666 ram, a thermal take 1200 watt PSU and a matrix 7970 platinum GPU. This system has run flawless for 2 years, I just purchased another used matrix 7970. I installed the latest drivers first, I made sure the device manager
Recognized both cards then I entered catylist control and enabled crossfire. The first thing I tried was heaven benchmark, the score was lower with
Both cards than one single card. Next I tried crysis 3 on ultra settings, with one card frames where around 32 on average with both cards
It jumped to 75 and even 85, I thought yeah it works then less than a minute into game the led indicator on the new card went instantly to max load
And the screen started tearing and artifacting and froze. Did this everytime, I then loaded furmark and did a stability test and it wouldn't even load before crashing, disabled crossfire and everything works fine. Is the new card bad or am I not doing something right.
Nate152
Hello immaturegizzmoe
Artifacting and crashing is definitely not good. If your gpu's are at stock speeds and you're getting artifacting and crashing, try them one at a time to see if both are ok or if one artifacts or crashes. If both are ok one at a time.......
I see your psu has four +12v rails, when running sli or crossfire a psu with a single +12v rail is preferred, this could be the problem too.
I imagine you have a 60hz monitor to get tearing at 75-85 FPS, you will want to enable v-sync to stop the tearing. This will cap the FPS to your monitors refresh rate.
Thank you for the reply, I checked and both cards are running at stock speed. I enabled vsync and tried crysis again and it ran fine no problems.
If I had a 120hz monitor would that help? I'm curious why with one card some games run over 60 hz fine, I ran one game at 130 with no problems. But its not as graphic intensive. I'm new at this so a lot I don't understand.
Nate152
Yes a 120hz monitor can go up to 120FPS with no screen tearing. if you can run a game at 130FPS on a 60 hz monitor and get no tearing by all means go for it.
I suppose it depends on the game but on a 60hz monitor anything over 60FPS and you should get screen tear.
