Headphone questions.
HappyBuddhaman
Hey guys,
I know this is an ASUS board, but I wanted to know what (if any) headphones everyone is using. I'm looking for a gaming (with mic) set, and there really isn't anywhere you can test them out.
Budget is $150.00 max. Want to use for online gaming and music, would like quality bass, none of that over enhanced crap.
Have seen the Logitech G930's, and the Corsair Vengeance 2100's (not spending $300 on a set of Astro A50's), people seem to have a lot of issues with the Orion Pro's, and I haven't seen a US release date for the Cerberus's.
Will be using a Formula VI MB with no additional sound-card.
13 REPLIES 13
Antronman
Level 11
http://www.amazon.com/Logitech-Wireless-Gaming-Headset-Surround/dp/B003VANOFY/ref=lp_402053011_1_1?s...
Great Quality ( based on reviews)
http://www.amazon.com/Turtle-Beach-Amplified-Headset-TBS-6052-01/dp/B00D6JBZBK/ref=sr_1_1?s=videogam...
Same for those.
Say hi to the next generation.
Peace is a lie, there is only Passion
Through passion, I gain strength
Through strength, I gain victory
Through victory, my chains are broken
The Republic of Gamers shall free me
arkejn
I have Ozone Spark, earlier got Creative but they were, well nothing special, I want to buy Vulcan or Echelon, alway wanted them 🙂
STATION WAGON PC:
CPU
: AMD Phenom II X6 1100T BE / A10 7700K MOBO: ASUS M4A79XTD EVO / ASUS Crossblade Ranger
COOLING: Coolermaster V8 PSU: Chieftec 80P 600W / Corsair RM850
RAM: Kingston HyperX T1 2x4GB DISK: Seagate 1TB, WD Green Caviar 1,5TB
CASE: Cooler Master Elite 330 / Corsair Carbide SPEC02 VIDEO: Asus GTX460 1GB DCU/TOP
G56JR
kb0sdq
Level 11
Howdy HappyBuddhaman,
For what it is worth, I was looking around for a set also. I bought Logitech H800 they are wireless with a usb transmitter and they also have Bluetooth so I have it linked to my phone when calls come in just slide the button and can talk. They are $99 new from Logitech, I got mine off of ebay for 54 bucks brand new. Have had them around six months and no issues.
As for sound the quality is pretty good bass is nice and the highs and mids are there as well.
Also I wear them for six to eight hours a day and they are comfortable and do not make my ears sweat.
If you want to go a step higher then the g930's are good but do not have Bluetooth
Hope this helps,
Happy ROG_n
Doug
Veracis
I have the g930. Great quality sound. Wireless. If battery runs low its cable is long enough to recharge while you continue playing and not hinder head movement. Programmable keys on the side. If you do not use the software (I don't) the keys allow you to pause/play, next song and previous song in iTunes by default.
Highly recommend them.. The issue I would guess is they are USB and do not go directly through the audio header.. I do not know if this uses the onboard SoundFX chips in the Maximus VI mobos or not.
i7-4770k @4.2 | EVGA 780ti | Maximus VI Hero | Seasonic 1000W Platinum | Seidon 120v AIO
Trident X 16GB 2400 | Samsung EVO 500GB | Seagate Barracuda 2TB | CM 690 III
Logitech G400 Mouse | G710 Keyboard | Razor gaming headset
ROG Swift pg278q G-Sync Monitor
HappyBuddhaman
Thank for the advice.
I have considered the G930's, but I'm putting a Formula VI in my build, and have read that a USB connection won't use any features of either a sound-card or any on-board audio.
beatendown
SteelSeries Siberia V2, nice sound quality.
FX8350 | 670 FTW x2 | HyperX 16g | Carbide Air540 | H100i | Sabertooth 990FX R2
I agree these are nice sounding
Current: MSI Xpower Gaming Titanium | 7700K | G Skill Ripjaws V 3000 16Gb | 960 EVO 500Gb | Intel 730 480Gb | Seasonic 1000 Platinum |
NZXT X62 | Acer XB270HU | EVGA 1080 ti FTW3
Secondary: R4BE | 4930K | G.SKILL 2400 16GB | Corsair AX 1500i
Intel 730 240GB + 480GB | EVGA GTX780 ti sli kpe | Custom H20
Revolution996
I have these..
http://www.overclockers.co.uk/showproduct.php?prodid=SP-018-CS
hooked up to..
http://www.amazon.co.uk/Express-Normalizer-Virtual-Speaker-Shifter/dp/B007RMMYFI
And find them fantastic, far better than a USB headset once you get them set up.
Revo.
HAF 932 / Intel i7 4790k / Alpenföhn K2 Mount Doom CPU Cooler / Asus Maximus VII Hero z97/
8GB Hyper X Beast @ 1866 / NVidia GTX980 / Crucial M4 128Gb SSD / 3x 1Tb HDD / 1x 2Tb HDD / PSU - Corsair HX1050 / Zonar DGX 5.1 Sound Card / Corsair K70 Keyboard / Logitech G502 Mouse / Monitor - VH242H / Corsair Vengeance 1400 Headset 😛
Motherland
I trust Plantronics to make good sound and build quality headsets.
http://www.amazon.com/Plantronics-GameCom-780-Surround-Headset/dp/B006ZS5ATM/ref=sr_1_1?s=videogames...
After reading some of the reviews maybe this model is not the same build quality as my old Plantronics headset was, I have a feeling profit margin is chipping away at the quality margin at most companies nowadays... sadly
