07-11-2019 08:38 AM
04-27-2021 08:01 AM
04-27-2021 05:46 PM
quexos wrote:
Two years later...still no new drivers, and broken sound card. @#$% you Asus! Props to C-Media for making excellent audio chips, but seriously, #$%@ Asus for butchering their implementation and providing ZERO support for them.
04-27-2021 06:00 PM
mulderfox wrote:
What are your symptoms?
11-21-2021 05:33 PM
mekler22 wrote:
One more thing: I noticed with my Xonar SE as well, that it always reverts to HeadPhones (Xonar SoundCard) and to change it back to speakers, I have to go to the Xonar Audio Center utility and click on speakers. It's really tedious. If anyone got a registry trick or anything to fix that, I'll be grateful!
N2G-WarMaster wrote:
I was looking to a solution regarding my Asus Xonar SE card dropping the speaker config after sleep/hibernation and found this topic.
11-22-2021 10:22 PM
quexos wrote:
In case you hadn't found it by now (hopefully this will trigger a notification for you guys/gals/they/them/its): USB Audio Stutter is gone or greatly reduced with later Windows versions (20Hx+) + a different main board. 1809 was terrible. New Asus "hacked-in" fix in the same version of drivers from AUG 2021 enables remembering your chosen output source via some added script that launches and changes it back after a restart. Cheap hack, but better than nothing.
01-26-2023 04:01 PM
mulderfox wrote:
No worries. I've been corresponding with them and they sent me a download link as soon as they finished this workaround. Yes, it is a cheap and somewhat annoying hack, but I guess it's better than nothing - as you said.
12-23-2023 10:49 AM
My problems with Xonar pale before yours but Im still feeling the loss of uising it
- the little DX management panel cant even be found anymore after a day of no sound output from it whatsoever something must be toast ://
I imagined for a moment installing the hardware in a new pc which might start some kind of firmware and maybe software download ... is this a bonkers cloud cuckoo-land idea ?
idk Im not a sound professional as I guess you are
01-19-2024 12:41 PM - edited 01-23-2024 04:28 AM
I have a Zonar SE installed today on my very standard HP Prodesk 400 g6 running Windows 11 23H2. I use the optical out to the amp and personally think it sounds great. I do get the very occasional tiny stutter for about 1/4 second and that is about it when using Spotify. I would rather not have it there at all but at least it is not a regular thing. I pretty much agree that it could be the issue will be the usb chip as mentioned earlier.
