Xonar Phoebus Audio Center force close
xjapan_hide
Just brought my Phoebus soundcard for a week (loving it so far) messing around the setting, and i found that when I
choose another profile in the audio center with Dolby Home Theater opened & enabled, it will force the audio center to close.
Just want to see if anybody is experiencing this or it's just me?
MB - Asus Rampage IV Extreme
CPU - I7 3930K
RAM - Corsair Vengeance 8GB X 4 (1600Mhz)
SSD- Plextor M5P 128GB x 2 (RAID 0)
Graphic - Inno 3D GTX 590
HD - WD Caviar Green 1.5TB
PS - SilverStone 1000W
CASE - HAF-X
Cooling - H100
Sound Card - Asus Xonar Phoebus
7 REPLIES 7
Raja
Can't recall having a problem myself. I have tried most of the profiles in that GUI and never had it closing as a result. I guess it could be down to one setting over-riding the other if you are applying things from both GUIs (I was only using one at a time).
Can you provide more specifics on which profiles, settings and what you have connected to the card etc??
Hi Raja, thank you for the quick reply.
It is not a specific profile causing the force close issue, it happens when I change the profile when I leave the Dolby Home Theater enabled and
on.
For example, I am using the music profile when I listen to music and play with the EQ in the Dolby Home Theater, then I decide to play game for
instance, choosing the gaming profile I save, then a window will pop up (You know, the windows whenever the application is not responding).
But if I disable or close the Dolby Home Theater before I choose another profile, it works fine.
The setting in the audio center is untouched, only play with the EQ in the Dolby Home Theater.
I had connected the soundcard using the 4pins molex to 6pins that came with the package.
CPU - I7 3930K
CASE - HAF-X
Cooling - H100
Raja
Not seen this myself, I will try to replicate if possible. Is your system overclocked?
Yes, I am oc to 4.5ghz, not too heavy so I doubt it caused the force close.
I think the driver got mess up or something...
CPU - I7 3930K
CASE - HAF-X
Cooling - H100
Raja
I'll try and replicate when I get back to my place and let you know.
Raja
Ok I have no problems at all my end changing profiles when Dolby Home Theater and the Phoebus GUI open. I can change settings in either GUI. The settings that overlap (Xear) simply disable DHT when they are enabled. I can also change to any saved profile without errors. I think it is down to something on your system. Either down to the drivers as you suggest or the overclock.
I am running the following in my system:
Corsair AX 1200
i7 3930K
Gskill F3-17000CL7-4GBHD at DDR3-2133 (16GB kit)
2 X GTX 460 watercooled in SLI
1 X GTX 570 dedictaed to Physx
Xonar ROG Phoebus using drivers on suport disc.
Win 7 64 bit SP1
-Raja
Ah, I thought so too, it should be the problem of my system or drivers...
Anyway, I want to say thank for your time and effort.
I will try to reinstall the driver and see where it goes.
CPU - I7 3930K
CASE - HAF-X
Cooling - H100
