04-12-2025 02:59 PM
Hello
I forgot to reconnect the Phoebus's 6-pin connector, so I reconnected it (with the PC off) and noticed that the blue display on the side of the card was gone (no idea if it's related or not, I've been plugging and unplugging a lot of things in the last two days).
Otherwise the card works
I think this problem happened to me at the very beginning, but I don't remember at all how the display appeared.
If anyone has any ideas, please let me know
Thanks
3 weeks ago - last edited 3 weeks ago
I don't have an answer, but just in case,
I no longer had the Headphone option, by connecting the earphone on HP out port (green), the option reappeared...
Tested with "cheap" headphones on red and green port and nothing....
And by changing the headphone settings, the display on the card returned, but no more blue
Normal gain: no display
High gain: red display
Extra gain: red display
Just to know, the blue is with which option (I had it before and I would like to put the same settings back)
Need to test with other headphone ?
Thanks
