SOLUTION ASUS Strix Soundcard - Strix Soar RAID PRO and DLX - Cold Boot Not Recognize
bogsha
Level 11
On a russian site (thx to user Kirych___83 for the tip) i found a solution to get your
soundcard back to work, if she dont get recognize at cold boot or for any other reasons.
It's only for people who are out of warranty and don't care if it breaks.
I did it on my Strix RAID DLX 4 days ago and my Soundcard works again.. no problems anymore.
At first I had extreme doubts that it would work and that it would be so easy.
For ASUS Strix Soar and ASUS Strix RAID PRO: (the two cards are almost identical)
Remove the two ceramic capacitors marked in red on the picture.
95430
Here the original PCB pictures for the Strix Soar and RAID PRO
Strix Soar
95431
Strix RAID PRO
95432
For ASUS Strix RAID DLX:
Remove this one ceramic capacitors marked in red on the picture.
95433
Here the original PCB picture for the Strix RAID DLX
95435
Do it on your own risk and only if you dont have warranty anymore. I only tested it on the ASUS Strix RAID DLX.
Source: https://forum.ixbt.com/topic.cgi?id=12:56114:1128#1128
6 REPLIES 6
michaelz649
I tried with my Strix Soar card and it works. Thanks for your help.
Flarkit
I also followed the suggestion from @Kirych___83  and my Strix Soar card is working again, after a few months without being detected in Windows 10! Thank you gentlemen
danhaa
On Asus Strix Pro version must remove 2 ceramic capacitors or 3? I remove 2 and working now
ThaSundanceKid
Im about to do it on my xonar essence 3.
These has to be the right ones right?
Do you have the adress to the russian site?
And yes ASUS, its really really bad when a hardware manufacturer cant get their hardware to work on the latest OS.
Like selling cars that cant run on gas
Did the hack, and it works for me too
