Not Booting at first time.
CesarSMX
hi there!
Well i have been searching for this problem, and i have found nothing. well actually is not a problem. its just that when i turn the pc first time on a day, the phoebus doesn't boot, i don't hear relays clicking, and don't get any audio, until i restart it, and it loads fine.
Does this happens to someone else???
Or somebody knows why is doing that??
any fix to this?'??
13 REPLIES 13
This appears to be part of a larger problem. For instance with my Asus Rampage II Extreme I experience waking up from sleep problems when the Xonar Phoebus is installed on any PCIe x1. I managed to solve the problem 100% by configuring the last slot to x8 (actually runs in x1 width).
To elaborate, the PCIe auto config with two GPUs installed by default is x16 x16 x1. I must run it in x16 x8 x8 for the Phoebus to not cause waking up from sleep problems. If I'm assuming correctly it appears the card doesn't like running on a x1 slot that's configured by the south bridge.
I have the same problem. But unfortunately, my motherboard supports no option to change the mode PCIE slots: (
Same Problem here 😞
dsp
on my rampage 3 extreme i plugged the phoebus in the last x16 slot but strange thing is gpu-z is still telling me my cards are @x16x2
if i am correct 1 card should now be @x8 right ? (slot 1-gtx580 - slot 2 - empty - slot 3 -gtx580- slot4 phoebus )
