Not Booting at first time.
CesarSMX
hi there!
Well i have been searching for this problem, and i have found nothing. well actually is not a problem. its just that when i turn the pc first time on a day, the phoebus doesn't boot, i don't hear relays clicking, and don't get any audio, until i restart it, and it loads fine.
Does this happens to someone else???
Or somebody knows why is doing that??
any fix to this?'??
13 REPLIES 13
Raja
Do you have the power cable plugged in? If so make sure it is secure an making proper contact.
Yes, everything is plugged in, and making good contact.
i have an Asus P8Z77-V-Deluxe, is on PCI exp 1x slot 1, wiht bios setup on 1X, could that be the issue???
Operation_Nadet
What power supply you use?
Mainboard:ASUS +6H
GPU: GTX 1080 Auros Gigabyte
CPU: R5 1600X stock
PSU: Be quiet straight power 10 500W
RAM: Trident Z DDR4 3600 @3,2 Ghz CL16
Cooler Master Silent Pro 1000w.
x7007 wrote:
You crazy, you want to burn his pc ??? Edit : good his message deleted :B i didn't want even to quote it. [/QUOTE}
Hahah what message?? i didn't see it
Raja@ASUS wrote:
Make a fresh install of the OS and try again. Chances are you have something sitting on your system that you should not. Also DO NOT unplug and plug the card in while the system is powered on - this may kill the card or damage the motherboard/CPU.
I'll try that, but i have less than a month that i installed it. and im to lazy to do that again haha, but if i must, i will.
x7007
Raja
CesarSMX wrote:
hi there!
any fix to this?'??
thegovernment
Plugging in the phoebus under power is what they deleted. Burn his pc by plugging a 6 pin under power? gimme a break.
hahahah yeah! i will do it for sure 😛
Well i think i found the solution. i just changed the slot from PCIE 1X_1 to 1X_4 and, changed bios setting to auto. and now is booting every time!. I will keep checking that bug.
9973
Greetings.
Well just to let you know, since i changed pcie slot, phoebus is booting since first time.
