06-14-2012 07:53 AM - last edited on 03-05-2024 02:16 AM by ROGBot
01-27-2023 05:05 AM
11-17-2012 02:41 AM
11-17-2012 03:52 AM
11-17-2012 04:31 AM
WTC wrote:
I believe you'll need to turn on FlexBass in your case. The audio stream in Youtube video, like MP3, is stereo. The sound will come out of the front 2 channels. I would guess the front channel parts of your headset do not have the ability to output low frequency component in the audio stream. Someone needs to redirect the low frequency part to subwoofer channel, and that someone would be FlexBass. Go to the FlexBass page, enable it, and set all speakers to "small speaker" and try again. You can also try adjusting the cut-off frequency and bass level sliders for the best result. Hope this helps.
Glasofruix wrote:
Flexbass > 80Hz cut-off > small speakers > bass boost less than 5 because higher values destroy the sound.
11-17-2012 05:28 AM
11-17-2012 06:49 AM
01-26-2013 12:20 AM
06-20-2013 12:39 PM
07-29-2013 11:29 PM
Rolfenstein wrote:
So I just got my Razer Tiamat 7.1 and there appears to be absolutely no bass. I googled quite alot and according to Razer you have to "configure" the audio device to 7.1 in the sound device tab, but I cant configure the Xonar Phoebus. Dolby doesn't do much to increase bass either. How the hell do I get bass on this sound card :|?
