10-29-2013
09:53 PM
- last edited on
03-06-2024
06:56 PM
by
ROGBot
10-29-2013 09:56 PM
10-29-2013 10:00 PM
10-30-2013 02:41 AM
10-30-2013 09:06 PM
11-01-2013 07:42 PM
Cageymaru wrote:
From what I understand it ASIO on the Phoebus was stillborn from the beginning. You sound like a person that really needs working drivers and features. I would return the Phoebus and get another product. The probability of Asus releasing new drivers for the Phoebus is less than 1%. If you can't return it, then I would like to send my condolences for your loss, and reluctantly welcome you to the fan club. Misery does love company; so you're welcome to stay.
11-01-2013 05:11 AM
Jynxx wrote:
Ok, so I have been trying to figure this out for weeks, and I thought that the combination of a clean Win8 install and the new drivers that just came out the other day would fix this, but it hasn't, so I am hoping someone wiser than I may have a solution for me.
I am a professional remixer, and I use a lot of DAWs (digital audio workstation), which rely on ASIO heavily. I am also a huge gamer, and absolutely need awesome 5.1 audio, otherwise I may as well be playing Pong or Space Invaders. So I figured the Xonar Phoebus was a great mix of both. Great gaming hardware and audio, with exactly the right specs for the audio work I do (24-bit 192khz is a must).
SO... now that you have some background, here is the problem. I use two programs more than any other, FL Studio and Adobe Audition. I just upgraded to the latest version of FL Studio (FLS 11), and everything works fine in there, always has. I also just upgraded to Adobe Audition CC (I was previously using CS6). In Audition CS6 everything worked fine as well, but Audition CC has some features and bug fixes that would really come in handy, plus my company pays for it, so I really want to use CC, but everytime I go into the Audio Hardware setup and select ASIO, I get an error that says:
The device settings could not be applied because the following error occurred:
The device could not be opened.
The last valid device settings will be used.
Now I have tried just about everything I can think of. I figured that it was an Audition problem, but no one there seems to be very helpful, and so it's no surprise that my problem wasn't solved. So, here I am. Clean install, new drivers... and the hope that someone on here can give me some magical setting that will somehow "open" the ASIO driver for Audition, so I am not forced to use the ASIO4ALL drivers, or even worse, the MME drivers. Yuck.
As I am sure you can tell by now, anyone who can actually help solve this issue will become my new personal hero.
Here is a screenshot, just for the heck of it:
http://img40.imageshack.us/img40/3107/tgkz.png
11-01-2013 05:55 AM
11-01-2013 07:29 PM
Tellus wrote:
To be honest i would advise you to get another card if you are in a hurry to get it working, or use windows 7. phoebus & win8/8.1 and asio ontop is just not gonna work as it is now. Most onboard cards work and sound better then the phoebus does in win8.
Best solution for you would be to run with onboard for games (if you have a motherboard that's made in the last few years) and then add a proper studio card for the remixing, that is if you can return/sell the phoebus.
11-02-2013 03:17 AM
