11-13-2017 03:59 AM
11-16-2017 11:38 AM
11-22-2017 06:31 PM
12-12-2017 12:47 AM
Jimmo4ka wrote:
So. I connected a sound card with a separate power supply - the problem remained. Checked with a grounded outlet - the problem remained.
Finally decided to move the card again from the video card and found out that there really is a problem in this.
If you remove the sound card from the video card further away, the noise disappears.
Unfortunately, PSAI slots do not allow the cards to be separated from each other for a significant distance. Perhaps there is another way to stop the noise. Is contact isolation possible?
12-01-2017 11:41 PM
