Trivial issue with GT-AXE16000 running 3.0.0.4.388_22237
david_mckee1
Since updating my netowrk to the latest firmware 3.0.0.4.388_22237, my client list and count is "stuck". Everything else seems to be working great, it's only the device connections being reported that isn't working properly. When I export the list, it's identical every time. Devices that haven't been connected in over a week are still listed as connected and no new deviced are being added. Wired and Wifi regaurdless of the node. Anyone else seeing this?
Routers / AiMesh Nodes:
  • GT-AXE16000 (Currently running as the primary router)
  • GT-AX11000
  • ASUS RT-AX89X AX6000 (Mesh)
  • 4X ZenWiFi AX XT8 AX6600 (Mesh)
  • RT-AX58U (Mesh)
  • RT-AC5300 (Mesh)
13 REPLIES 13
@Saltgrass thanks for your reply.
Is your GT-AXE16000 running on firmware 3.0.0.4.388 22237-g9120e16 ?
Does it work ok?
Thanks
jzchen
I have run 3.0.0.4.388.22237 for a while and I was getting dropped nodes as mentioned in another thread.
I updated to 9.0.0.6.102.3506 yesterday after rebooting the RT-AX86U so it relinked (via 2.5 G ethernet) as an AiMesh node.
If you are happy with how it is performing then I do not recommend updating it to be honest...
riskmaker76
I am having the same exact issue - the client list and count never changes.  Anyone figure out how to fix this?  I am on the latest firmware.
Thanks!
I have a decent amount of nodes but not as many as the OP.  I see an issue with the device listing on Apple iOS (16.6) ASUS Router app running on an iPhone X.  I do not readily see the same issue on Android app nor on ASUSwrt (WebGUI).  It helped me (I believe) to flash the 3/21 beta firmware and then flash back to 3.0.0.4.388.23012 (which is the current latest).
