RT-BE88U : Using a USB Hub to Expand USB Port on Router for Simultaneous 4G Tether and NAS?
Basspig
Given there is only one USB 3.2 port on the RT-BE88U, I already have my 6TB portable HD plugged into it for NAS use.
I want to know if I can expand it with a USB hub to do the following:
Add a second HDD
Tether off a 4G cellphone in times of storm aftermath when broadband might be down.
Is this possible? Any recommendations on particular USB hubs to use?
Regards,
Mark
"If it doesn't cause an earthquake, you need a bigger subwoofer."
0 REPLIES 0
