01-09-2024 07:30 AM
Hello,
I tried upgrading my GT-AXE16000 firmware from version 3.0.0.4.388_23012 to version 3.0.04.388_24329 and encountered several issues.
I have tried the following troubleshooting steps:
When I revert to the previous firmware version (3.0.0.4.388_23012) all the issues go away.
Any help would be greatly appreciated.
01-11-2024 07:06 AM
I am going to reach back out to Asus support and let them know the hard reset did not address the issue. I want give them an opportunity troubleshoot further. If they don't come back with anything I will try the beta firmware as a troubleshooting step. If it works that would at least tell me version 3.0.04.388_24329 is my issue and not the router or a setting. Thanks for the help!
01-11-2024 08:06 AM
Yes, mine is also a node since before release of 24329. It appears to be working normally as a node, Ethernet backhauled…
I’m not personally fond of that beta firmware as it seemed to knock out ethernet connections, WAN, LAN, or both I did not determine…. (Primary router, AiProtection ON as reference).
